HP 250 G9 IPA50 LA-K203P Schematic
This Compal LA-K203P schematic, revision 1.0 dated 2020-07-26, documents the TGL-U platform motherboard. The board is built around a TGL-U CPU platform with DDR4 3200MHz 1.2V memory configured as dual channel interleaved across two DDR4-SO-DIMM slots. The embedded controller is an ENE KB9052Q. Audio is handled by a Realtek ALC3247-CG codec. The system BIOS is stored on a 16MBytes SPI ROM. Wired networking is provided by a Realtek RTL8111HSH-CG LAN IC. A card reader controller AK6485RB63-GLF-GR is present. Thermal monitoring is managed by a G753T11U sensor. The board also includes an Infineon SLB9670VQ2.0 TPM module.
Q: What is the board number and project code for this motherboard?
A: The board number and project code are both LA-K203P.
A: The embedded controller is an ENE KB9052Q.
Q: What type of memory does this motherboard support?
A: This motherboard supports DDR4 3200MHz 1.2V memory in a dual channel interleaved configuration across two DDR4-SO-DIMM slots.
A: The audio codec is a Realtek ALC3247-CG.
Q: What LAN IC is used on this motherboard?
A: The LAN IC is a Realtek RTL8111HSH-CG.
| Brand | Compal |
| Model | TGL-U |
| Project Code | LA-K203P |
| Board Number | LA-K203P |
| Revision | 1.0 |
| Date | 2020-07-26 |
| CPU Platform | TGL-U |
| EC / KBC | ENE KB9052Q |
| Audio Codec | ALC3247-CG |
| BIOS / SPI Flash | 16MBytes |
| LAN IC | RTL8111HSH-CG |
| Card Reader IC | AK6485RB63-GLF-GR |
| Thermal Sensor | G753T11U |
| TPM | SLB9670VQ2.0 |
| RAM Type | DDR4 3200MHz 1.2V |
| RAM Architecture | Dual Channel Interleaved |
| RAM Quantity / Slots | DDR4-SO-DIMM X2 |
