Schematic hp compaq nc4400 hau20 la-3031p rev 1.0 schematic
hp compaq nc4400 hau20 la-3031p_rev 1.0 schematic
hau20 la-3031p_rev 1.0.pdf
BrandCompal
Board NumberLA-3031P
Revision1.0
Date2006-03-22
CPU PlatformMobile Yonah uFCPGA with Intel Calistoga_GM+ICH7-M core logic
CPU ModelMobile Yonah & Merom uFCPGA-478 CPU
CPU SocketuFCPGA-478
PCH / SouthbridgeIntel ICH7-M
GPU TypeIntel Calistoga GMCH 945GM
Graphics ArchitectureDDR2 -400/533/667 533/667MHz
EC / KBCSMSC KBC 1021
Audio CodecAD1981
BIOS / SPI FlashSST49LF008A Flash ROM
BIOS Flash Exact ModelSST49LF008A
BIOS Flash ManufacturerSST
EC Flash / ROM25LF080A SPI ROM
RAM TypeDDR2
RAM ArchitectureDDR-SO-DIMM X2
RAM Quantity / Slots2
Thermal SensorADM1032AR
LAN ICBCM5753M
WiFi / WLAN ICHeavenly 2.0 BT Conn
Card Reader ICTI PCI6612
Charging ICCH7307C-DE
The Compal LA-3031P revision 1.0 motherboard is designed for the Mobile Yonah and Merom uFCPGA-478 CPU platform with Intel Calistoga GMCH 945GM and ICH7-M core logic. The system BIOS is stored on an SST49LF008A Flash ROM, while the EC firmware is managed by a 25LF080A SPI ROM paired with the SMSC KBC 1021 keyboard controller. Memory architecture consists of two DDR2 SO-DIMM slots supporting DDR2-400/533/667. The integrated audio solution uses the AD1981 codec, and networking is provided by the BCM5753M Gigabit LAN controller. Thermal monitoring is handled by the ADM1032AR sensor, and the CardBus interface is managed by the TI PCI6612 controller. The DVI output is driven by the CH7307C-DE controller.
A: The BIOS is stored on an SST49LF008A Flash ROM.
Q: What EC/KBC chip is used on this motherboard?
A: The EC/KBC is the SMSC KBC 1021, with its firmware stored on a 25LF080A SPI ROM.
Q: What is the memory configuration of this motherboard?
A: The motherboard supports two DDR2 SO-DIMM slots with DDR2-400/533/667 memory.
Q: What is the CPU socket and platform for this motherboard?
A: The motherboard uses a uFCPGA-478 socket for Mobile Yonah and Merom CPUs, with the Intel Calistoga GMCH 945GM and ICH7-M chipset.
  • HP Compaq NC4400=1=HAU20 LA-3031P_Rev 1.0.zip
