Schematic hp dv6 quanta qt6 rev-2a schematic
hp_dv6 quanta_qt6_rev-2a schematic
hp_dv6=1=quanta_qt6_rev-2a.pdf
BrandQuanta Computer Inc.
Project CodeQT6NB5
Revision2A
DateWednesday, February 27, 2008
CPU PlatformPenryn 478P (uPGA)/35W
PCH / SouthbridgeICH-9M
EC / KBCKB3926 C0
Audio CodecIDT92HD71B7X
Charging ICISL6251AHAZ-T
Power IC(s)ISL6237IRZ-T, ISL6266A, TPS51116REGR, RT8204
RAM TypeDDR II
RAM ArchitectureDDRII-SODIMM
RAM Quantity / Slots2
LAN ICRTL8102E
Card Reader ICRTS5158E
Audio AmplifierTPA6017A2
Thermal SensorLIS3LV02DL
The Quanta QT6NB5 project is a notebook motherboard platform dated February 27, 2008, revision 2A. It is built around an Intel Penryn 478P (uPGA) CPU with a 35W TDP, paired with the Cantiga northbridge and ICH-9M southbridge. System memory consists of two DDRII-SODIMM slots supporting DDRII 667/800 MHz modules. The embedded controller is a KB3926 C0. Power management is handled by an ISL6237IRZ-T system power IC, an ISL6266A CPU core regulator, a TPS51116REGR DDR_VTERM regulator, and an RT8204 for VCCP and GMCH voltages. The charging IC is an ISL6251AHAZ-T. Audio is provided by an IDT92HD71B7X codec with a TPA6017A2 amplifier. Networking uses a Realtek RTL8102E 10/100 LAN controller. A Realtek RTS5158E card reader and an ST LIS3LV02DL accelerometer are also present on this platform.
A: The embedded controller is a KB3926 C0.
A: The system charger IC is an ISL6251AHAZ-T.
Q: What audio codec and amplifier are used on this motherboard?
A: The audio codec is an IDT92HD71B7X, and the audio amplifier is a TPA6017A2.
Q: What memory type and configuration does this motherboard support?
A: It supports DDRII memory via two DDRII-SODIMM slots at 667/800 MHz.
  • HP_DV6=1=Quanta_QT6_Rev-2A.zip
