Schematic HP EliteBook 745 G6 6050A3044101-MB-A01 Schematic
BrandInventec
ModelLLARGA-6050A3044101-MB-AX2
Motherboard ManufacturerInventec Corporation
Project CodeLLARGA
Board Number6050A3044101-MB-AX2
RevisionE2
Date21-OCT-2002
CPU PlatformAPU FP5
EC / KBCWINB_W83L771AWG
Charging ICINTERSIL_ISL9538HRZ
Power IC(s)RT8068AZQW, RT8097ALGE, P0503BEA, ISL62771, NB680AGQ, NB685AGQ, G5335QT1, UNB685AGQ
RAM TypeDDR4_SO-DIMM
RAM ArchitectureSO-DIMM
RAM Quantity / Slots2 (DDR4_SO-DIMM0, DDR4_SO-DIMM1)
Thermal SensorNUVOTON_NCT7717W
LAN ICLAN NIC (listed in Table of Contents)
WiFi / WLAN ICM.2 WLAN & BT (listed in Table of Contents)
HDMI Level ShifterPERICOM_PI3DPX1207B
USB Hub ICUSB 2.0 HUB (listed in Table of Contents)
Card Reader ICSmart Card D/B (listed in Table of Contents)
Audio CodecAudio Codec (listed in Table of Contents)
Charger ArchitectureC PD (USB-C Power Delivery)
GPU TypeAPU FP5 (integrated)
Graphics ArchitectureAPU FP5
Document Number6321310xxxxx-0-0
This Inventec LLARGA-6050A3044101-MB-AX2 motherboard, revision E2, is built around the AMD APU FP5 platform. The system memory architecture consists of two DDR4 SO-DIMM slots. Power management is handled by an Intersil ISL9538HRZ USB-C PD charger, with voltage regulation provided by a combination of Richtek and Intersil controllers including the RT8068AZQW, RT8097ALGE, and ISL62771. The embedded controller is a Winbond W83L771AWG. The board features a Pericom PI3DPX1207B HDMI level shifter, a Nuvoton NCT7717W thermal sensor, and a dedicated LAN NIC. The system supports USB-C Power Delivery charging and includes a USB 2.0 hub, M.2 WLAN/BT, and Smart Card reader interfaces.
Q: What is the board number and revision of this motherboard?
A: The board number is 6050A3044101-MB-AX2, revision E2.
A: The embedded controller is a Winbond W83L771AWG.
Q: What charging IC and architecture does this board use?
A: The charging IC is an Intersil ISL9538HRZ, supporting USB-C Power Delivery (C PD) architecture.
Q: What type of memory does this motherboard support?
A: This motherboard supports DDR4 memory in two SO-DIMM slots.
  • HP EliteBook 745 G6 6050A3044101-MB-A01 Schematic.pdf
