HP EliteBook 745 G6 6050A3044101-MB-A01 Schematic
This Inventec LLARGA-6050A3044101-MB-AX2 motherboard, revision E2, is built around the AMD APU FP5 platform. The system memory architecture consists of two DDR4 SO-DIMM slots. Power management is handled by an Intersil ISL9538HRZ USB-C PD charger, with voltage regulation provided by a combination of Richtek and Intersil controllers including the RT8068AZQW, RT8097ALGE, and ISL62771. The embedded controller is a Winbond W83L771AWG. The board features a Pericom PI3DPX1207B HDMI level shifter, a Nuvoton NCT7717W thermal sensor, and a dedicated LAN NIC. The system supports USB-C Power Delivery charging and includes a USB 2.0 hub, M.2 WLAN/BT, and Smart Card reader interfaces.
A: The board number is 6050A3044101-MB-AX2, revision E2.
A: The embedded controller is a Winbond W83L771AWG.
Q: What charging IC and architecture does this board use?
A: The charging IC is an Intersil ISL9538HRZ, supporting USB-C Power Delivery (C PD) architecture.
A: This motherboard supports DDR4 memory in two SO-DIMM slots.
| Brand | Inventec |
| Model | LLARGA-6050A3044101-MB-AX2 |
| Motherboard Manufacturer | Inventec Corporation |
| Project Code | LLARGA |
| Board Number | 6050A3044101-MB-AX2 |
| Revision | E2 |
| Date | 21-OCT-2002 |
| CPU Platform | APU FP5 |
| EC / KBC | WINB_W83L771AWG |
| Charging IC | INTERSIL_ISL9538HRZ |
| Power IC(s) | RT8068AZQW, RT8097ALGE, P0503BEA, ISL62771, NB680AGQ, NB685AGQ, G5335QT1, UNB685AGQ |
| RAM Type | DDR4_SO-DIMM |
| RAM Quantity / Slots | 2 (DDR4_SO-DIMM0, DDR4_SO-DIMM1) |
| Thermal Sensor | NUVOTON_NCT7717W |
| LAN IC | LAN NIC (listed in Table of Contents) |
| WiFi / WLAN IC | M.2 WLAN & BT (listed in Table of Contents) |
| HDMI Level Shifter | PERICOM_PI3DPX1207B |
| USB Hub IC | USB 2.0 HUB (listed in Table of Contents) |
| Card Reader IC | Smart Card D/B (listed in Table of Contents) |
| Audio Codec | Audio Codec (listed in Table of Contents) |
| Charger Architecture | C PD (USB-C Power Delivery) |
| GPU Type | APU FP5 (integrated) |
| Graphics Architecture | APU FP5 |
| Document Number | 6321310xxxxx-0-0 |
6050A3044101-MB-AX2
APU FP5
W83L771AWG
ISL9538HRZ
G5335QT1
ISL62771
NB680AGQ
NB685AGQ
P0503BEA
RT8068AZQW
RT8097ALGE
UNB685AGQ
DDR4
NCT7717W
PI3DPX1207B
APU FP5
6050A3044101-MB-AX2
APU FP5
W83L771AWG
ISL9538HRZ
G5335QT1
ISL62771
NB680AGQ
NB685AGQ
P0503BEA
RT8068AZQW
RT8097ALGE
UNB685AGQ
DDR4
NCT7717W
PI3DPX1207B
APU FP5
