hp mini 210 quanta annika ab540 41-ab5400-e00g rev 1a 1
This Quanta Computer Inc. block diagram, revision A dated October 30, 2009, details a platform built around the Intel Pineview-M CPU and Intel Tigerpoint Southbridge. The system memory architecture is DDR2 Single Channel with one SO-DIMM slot supporting up to 2GB. Integrated graphics are provided by the GFX CORE. The embedded controller is a KB3926D2, and the audio subsystem is handled by an ALC269 codec. Wired networking is provided by a Realtek RTL8103EL-VB 10/100 LAN IC, and a GL816 card reader controller is present. The system charger is an ISL6251AHAZ-T, with power management handled by multiple ICs including RT8209A, RT8206, RT8207, RT8152D, and RT9025. The BIOS is stored on an SPI flash memory.
A: The embedded controller is a KB3926D2.
A: The system charger is an ISL6251AHAZ-T, with a SYSTEM CHARGER architecture.
Q: What LAN IC is used?
A: The wired networking is provided by a Realtek RTL8103EL-VB 10/100 LAN IC.
A: The platform uses DDR2 Single Channel memory with one SO-DIMM slot, supporting up to 2GB.
| Project Code | BLOCK DIAGRAM |
| Revision | A |
| Date | Friday, October 30, 2009 |
| CPU Platform | Intel Pineview-M |
| PCH / Southbridge | Intel Tigerpoint |
| EC / KBC | KB3926D2 |
| Audio Codec | ALC269 |
| BIOS / SPI Flash | SPI Flash |
| Charging IC | ISL6251AHAZ-T |
| Charger Architecture | SYSTEM CHARGER |
| Power IC(s) | RT8209A, RT8206, RT8207, RT8152D, RT9025, RT9025 |
| RAM Type | DDR2 |
| RAM Architecture | Single Channel |
| RAM Quantity / Slots | 1 |
| LAN IC | Realtek RTL8103EL-VB |
| Card Reader IC | GL816 |
| GPU Type | Integrated |
| Graphics Architecture | GFX CORE |
