HP Omen 15-EN DAG3EFMBEE0 Schematic
This Quanta G3EFNB5 motherboard is built on the AMD Cezanne platform with an FP6 BGA CPU socket. The board features a dGPU architecture using either an NVIDIA GN20-E4 or GN20-E3 GPU. System memory consists of two DDR4 3200MHz SODIMM slots, each supporting up to 16GB. The embedded controller is an IT5570 KBC. Audio is handled by an ALC3315-CG codec. The BIOS is stored on a 1.8V SPI ROM. The charging architecture is managed by a TPS65987DDJ PD controller. Networking is provided by a Realtek RTL8118ASH-CG LAN IC. The card reader uses a Genesys Logic GL9750H-OIY04 controller. USB power delivery is managed by a TPS2546 hub IC. HDMI signal level shifting is performed by a PI3HDX12211ZHEX re-driver.
A: The project code is G3EFNB5, and the revision is Custom1A1, dated October 8, 2020.
A: The embedded controller is an IT5570 KBC.
A: The board supports either an NVIDIA GN20-E4 (80W MAX-Q) or GN20-E3 (80W MAX-P) dGPU.
A: The charging architecture uses a TPS65987DDJ PD controller.
A: The audio codec is an ALC3315-CG.
Reuse permitted only with source attribution.
| Motherboard Manufacturer | Quanta Computer Inc. |
| Project Code | G3EFNB5 |
| Revision | Custom1A1 |
| Date | Thursday, October 08, 2020 |
| CPU Platform | AMD Cezanne |
| CPU Socket | FP6 BGA |
| GPU Type | dGPU |
| dGPU Chip Number | GN20-E4, GN20-E3 |
| EC / KBC | IT5570 |
| Audio Codec | ALC3315-CG |
| BIOS / SPI Flash | SPI ROM (1.8V) |
| Charging IC | TPS65987DDJ |
| RAM Type | DDR4 3200MHz |
| RAM Architecture | SODIMM |
| RAM Quantity / Slots | 2 |
| LAN IC | RTL8118ASH-CG |
| Card Reader IC | GL9750H-OIY04 |
| USB Hub IC | TPS2546 |
| HDMI Level Shifter | PI3HDX12211ZHEX |
G3EFNB5
Project Code
AMD Cezanne
dGPU
Graphics
GN20-E3
Graphics
GN20-E4
Graphics
IT5570
ALC3315-CG
TPS65987DDJ
Charging / PD IC
DDR4 3200MHZ
RTL8118ASH-CG
LAN Controller
GL9750H-OIY04
Card Reader IC
TPS2546
USB Controller
PI3HDX12211ZHEX
Signal Conditioning IC
G3EFNB5
Project Code
AMD Cezanne
dGPU
Graphics
GN20-E3
Graphics
GN20-E4
Graphics
IT5570
ALC3315-CG
TPS65987DDJ
Charging / PD IC
DDR4 3200MHZ
RTL8118ASH-CG
LAN Controller
GL9750H-OIY04
Card Reader IC
TPS2546
USB Controller
PI3HDX12211ZHEX
