Schematic HP Omen 15-EN DAG3EFMBEE0 Schematic
Motherboard ManufacturerQuanta Computer Inc.
Project CodeG3EFNB5
RevisionCustom1A1
DateThursday, October 08, 2020
CPU PlatformAMD Cezanne
CPU SocketFP6 BGA
GPU TypedGPU
dGPU Chip NumberGN20-E4, GN20-E3
EC / KBCIT5570
Audio CodecALC3315-CG
BIOS / SPI FlashSPI ROM (1.8V)
Charging ICTPS65987DDJ
RAM TypeDDR4 3200MHz
RAM ArchitectureSODIMM
RAM Quantity / Slots2
LAN ICRTL8118ASH-CG
Card Reader ICGL9750H-OIY04
USB Hub ICTPS2546
HDMI Level ShifterPI3HDX12211ZHEX
This Quanta G3EFNB5 motherboard is built on the AMD Cezanne platform with an FP6 BGA CPU socket. The board features a dGPU architecture using either an NVIDIA GN20-E4 or GN20-E3 GPU. System memory consists of two DDR4 3200MHz SODIMM slots, each supporting up to 16GB. The embedded controller is an IT5570 KBC. Audio is handled by an ALC3315-CG codec. The BIOS is stored on a 1.8V SPI ROM. The charging architecture is managed by a TPS65987DDJ PD controller. Networking is provided by a Realtek RTL8118ASH-CG LAN IC. The card reader uses a Genesys Logic GL9750H-OIY04 controller. USB power delivery is managed by a TPS2546 hub IC. HDMI signal level shifting is performed by a PI3HDX12211ZHEX re-driver.
A: The project code is G3EFNB5, and the revision is Custom1A1, dated October 8, 2020.
A: The embedded controller is an IT5570 KBC.
A: The board supports either an NVIDIA GN20-E4 (80W MAX-Q) or GN20-E3 (80W MAX-P) dGPU.
A: The charging architecture uses a TPS65987DDJ PD controller.
A: The audio codec is an ALC3315-CG.
Reuse permitted only with source attribution.
  • HP Omen 15-EN DAG3EFMBEE0 Schematic.pdf
