Schematic hp probook 450 g2 zpl40 zpl50 zpl70 la-b181p rev 0.5 schematic
BrandCompal
Model NameLA-B181P
Board NumberLA-B181P
Revision0.5
Date2014/02/18
CPU PlatformIntel Broadwell U / Haswell
EC / KBCSMSC MEC1322-N
Audio CodecRealtek ALC3227
BIOS / SPI FlashSYS BIOS ROM 8MB
RAM TypeDDR3L 1600MHz
RAM Architecture204pin DDRIII-SO-DIMM X2
LAN ICRealtek RTL8161GSH-CG
Card Reader ICRT5237-GR
GPU TypeAMD Topaz VGA 128Mx16 / 256Mx16 DDR3 x4 VRAM
Charging ICBQ24735RSMR
Power IC(s)RT8243AZQW, RT8207MZQW, SY8206DQNC, SY8003DFC, RT8880BGQW, TPS51622ARSMR
This Compal LA-B181P schematic, revision 0.5 dated 2014/02/18, details a motherboard designed for Intel Broadwell U and Haswell processors with DDR3L memory architecture. The platform utilizes an SMSC MEC1322-N embedded controller and features an 8MB SYS BIOS ROM. Memory configuration supports two 204-pin DDRIII SO-DIMM slots operating at 1600MHz. Graphics are handled by an AMD Topaz VGA solution with 128Mx16 or 256Mx16 DDR3 VRAM. The audio subsystem is built around a Realtek ALC3227 codec, while networking is provided by a Realtek RTL8161GSH-CG Gigabit Ethernet controller. A Realtek RT5237-GR manages the card reader interface. The power delivery architecture includes a BQ24735RSMR charger IC and multiple DC/DC converters including RT8243AZQW, RT8207MZQW, SY8206DQNC, SY8003DFC, RT8880BGQW, and TPS51622ARSMR.
Q: What is the board number and revision of this schematic?
A: The board number is LA-B181P, revision 0.5.
A: The embedded controller is an SMSC MEC1322-N.
A: The system BIOS ROM is 8MB in capacity.
Q: What memory type and configuration does this board support?
A: The board supports DDR3L 1600MHz memory via two 204-pin DDRIII SO-DIMM slots.
Q: What GPU is used on this motherboard?
A: The discrete GPU is an AMD Topaz VGA with 128Mx16 or 256Mx16 DDR3 VRAM.
  • HP_ProBook_450_G2=ZPL40_ZPL50_ZPL70_LA-B181P_Rev_0.5_DR-BIOS.COM.zip
