Lenovo Ideapad Gaming 3 NM-D191 Schematic
This LCFC L350 A+N1.0 motherboard is built on the AMD RENOIR H platform with DDR4 memory architecture supporting dual-channel SO-DIMM x2 configuration at 3200MT/s. The discrete graphics subsystem features an NV N18P-G61/G62 GPU with 4GB GDDR6 memory across four chips. The system BIOS is stored on a W25Q128JWSIQ SPI ROM with 16MB capacity. Embedded controller functionality is handled by an IT8227E-128/CX in LQFP package. Audio processing is managed by a Realtek ALC3287 HD audio codec. Wired networking is provided by a Realtek RTL8111GU LAN chip, while wireless connectivity uses an NGFF WLAN&BT module. The USB-C charging and power delivery is controlled by a Realtek RTS5449E controller. A PI3EQX7502MZDEX USB 3.0 redriver is used for signal conditioning. The board also includes an NPCT750LABYX TPM module and a Realtek RTS5449E Type-C controller.
A: The BIOS SPI flash is a W25Q128JWSIQ with 16MB capacity.
A: The embedded controller is an IT8227E-128/CX in LQFP package.
Q: What is the discrete GPU configuration on this board?
A: The discrete GPU is an NV N18P-G61/G62 with 4GB GDDR6 memory across four chips.
A: The memory architecture is dual-channel DDR4 SO-DIMM x2 supporting 3200MT/s.
A: The USB-C charging and power delivery is handled by a Realtek RTS5449E controller.
| Brand | LCFC (LC Future Center) |
| Model | L350 A+N1.0 |
| Motherboard Manufacturer | LC Future Center |
| Project Code | RENOIR-H with DDR4 + N18P-G61/G62 |
| Board Number | L350 |
| Revision | 1.0 |
| Date | 2020-05-09 |
| CPU Platform | AMD RENOIR H |
| GPU Type | NV N18P-G61/G62 |
| Graphics Architecture | GDDR6*4 4GB |
| EC / KBC | IT8227E-128/CX |
| EC/KBC Package | LQFP |
| BIOS / SPI Flash | W25Q128JWSIQ |
| BIOS Flash Capacity | 16MB |
| Audio Codec | Realtek ALC3287 |
| Charging IC | Realtek RTS5449E |
| RAM Type | DDR4 |
| RAM Quantity / Slots | DDR4 SO-DIMM x2 |
| LAN IC | Realtek_RTL8111GU |
| WiFi / WLAN IC | NGFF WLAN&BT |
| USB Hub IC | PI3EQX7502MZDEX |
| Card Reader IC | NPCT750LABYX |
| Thermal Sensor | FFC cable to SB |
DDR4
Project Code
G62
Project Code
N18P-G61
Project Code
L350
Board Number
AMD RENOIR H
NV N18P-G61/G62
Graphics
GDDR6*4 4GB
Graphics
IT8227E-128/CX
ALC3287
RTS5449E
Charging / PD IC
DDR4
REALTEK_RTL8111GU
LAN Controller
NGFF (WLAN/BT)
WiFi / WLAN
PI3EQX7502MZDEX
USB Controller
NPCT750LABYX
Card Reader IC
DDR4
Project Code
G62
Project Code
N18P-G61
Project Code
L350
Board Number
AMD RENOIR H
NV N18P-G61/G62
Graphics
GDDR6*4 4GB
Graphics
IT8227E-128/CX
ALC3287
RTS5449E
Charging / PD IC
DDR4
REALTEK_RTL8111GU
LAN Controller
NGFF (WLAN/BT)
WiFi / WLAN
PI3EQX7502MZDEX
USB Controller
NPCT750LABYX
Card Reader IC
