Schematic Lenovo Thinkbook 14s yoga gen2 LA-M062P Schematic
BrandCompal
Project CodeHLXB5
Board NumberLA-M062P
Revision1A
Date2021.12.24
CPU PlatformAMD Barcelo Processor with MX450
GPU TypeN18S-G5
Graphics ArchitectureMX450
EC / KBCENE KB9022
Audio CodecRealtek ALC3287
BIOS / SPI Flash32MB or 16MB SPI ROM
Charging ICTI TPS65994AD
RAM TypeDDR4 up to 3200Mbps
RAM ArchitectureCHA SO-DIMM, CHB memory down
Card Reader ICRealtek RTS5232S
LAN ICRealtek RTL8111H
WiFi / WLAN ICWLAN/BT 2230 conn.
HDMI Level ShifterParade PS8409
This Compal LA-M062P motherboard, project code HLXB5, revision 1A, dated 2021.12.24, is built around the AMD Barcelo processor platform with an N18S-G5 MX450 discrete GPU. The system memory architecture consists of DDR4 up to 3200Mbps, with one CHA SO-DIMM slot and CHB memory down configuration. The embedded controller is an ENE KB9022, and the audio codec is a Realtek ALC3287. The BIOS/SPI flash is configurable as either 32MB or 16MB SPI ROM. Charging is managed by a TI TPS65994AD PD controller. The board integrates a Realtek RTS5232S card reader, a Realtek RTL8111H LAN IC, and a Parade PS8409 HDMI level shifter. Wireless connectivity is provided via a WLAN/BT 2230 connector.
Q: What is the EC/KBC model used on this motherboard?
A: The embedded controller is an ENE KB9022.
Q: What is the BIOS/SPI flash configuration?
A: The BIOS/SPI flash is configurable as either 32MB or 16MB SPI ROM.
A: The charging IC is a TI TPS65994AD.
A: The memory architecture is DDR4 up to 3200Mbps, with one CHA SO-DIMM slot and CHB memory down configuration.
  • Lenovo Thinkbook 14s yoga gen2 LA-M062P Schematic.pdf
