lenovo thinkpad s5-s540 vius6 la-a171p rev 1.0
This Compal LA-A171P motherboard, model VIUS6, project code Guinness-2, revision 1.0_Final, is built around the Intel Shark Bay ULT processor platform. The board features an AMD SUN XT S3 discrete GPU and supports up to two DDR3L SO-DIMM memory modules operating at 1600 MHz. The embedded controller is a KB9012, and the system utilizes a SPI ROM for BIOS storage. Audio is handled by a Realtek ALC3232 codec, while networking is provided by a Realtek RTL8111GUS LAN IC. A Realtek RTS5227 card reader controller and a Fintek F75303MENE thermal sensor are also integrated into the design.
A: The board number is LA-A171P, and the project code is Guinness-2.
A: The embedded controller is a KB9012.
A: It supports DDR3L memory in SO-DIMM form factor, with two slots available.
Q: What discrete GPU is used on this motherboard?
A: The discrete GPU is an AMD SUN XT S3.
| Model | VIUS6 |
| Project Code | Guinness-2 |
| Board Number | LA-A171P |
| Revision | 1.0_Final |
| Date | 2013/02/20 |
| Document Number | 4019OJ |
| CPU Platform | Intel Shark Bay ULT |
| GPU Type | AMD SUN XT S3 |
| EC / KBC | KB9012 |
| Audio Codec | Realtek ALC3232 |
| RAM Type | DDR3L |
| Card Reader IC | Realtek RTS5227 |
| LAN IC | Realtek RTL8111GUS |
| Thermal Sensor | Fintek F75303MENE |
