lenovo thinkpad x1 wistron note lnl-1
This Wistron Corporation motherboard, documented under number A31101 dated March 7, 2011, is built around the Intel Sandy Bridge CPU platform paired with the Intel Cougar Point PCH. The system utilizes integrated graphics from the GMCH GFX core and supports dual-channel DDR3 1333MHz memory via two 204-pin SODIMM slots. Power management is handled by a TPS51220ARSN system DC/DC converter, a BQ24742 battery charger/selector, and multiple VT and MAXIM regulators. The embedded controller is a VBG25HV KBC communicating over the LPC bus. Audio is provided by an ALC269 codec over the Azalia/HD Audio interface. The board features an SPI flash for BIOS storage, an EMC1428 thermal sensor on the SMBus, a 4-in-1 media card reader, a uPD720200A USB 3.0 hub controller, an RTL8111 Gigabit LAN IC, and an Intel LEWISVILLE WLAN card. An FDILVDS level shifter supports the HDMI port.
Q: What is the embedded controller (EC/KBC) used on this motherboard?
A: The embedded controller is a VBG25HV KBC, communicating via the LPC bus at 33MHz.
Q: What charging IC and architecture does this board use?
A: The charging IC is a BQ24742 battery charger/selector, managing main battery and DC-IN power input.
Q: What is the memory configuration supported by this motherboard?
A: The board supports dual-channel DDR3 1333MHz memory using two 204-pin DDR3 SODIMM slots (Channel A and Channel B).
Q: What LAN and WLAN controllers are present on this board?
A: The LAN controller is an RTL8111, and the WLAN card is an Intel LEWISVILLE module connected via Mini PCI-E.
| Document Number | A31101 |
| Date | Monday, March 07, 2011 |
| CPU Platform | Intel Sandy Bridge |
| PCH / Southbridge | Intel Cougar Point |
| GPU Type | Integrated Graphics (GMCH GFX CORE) |
| Graphics Architecture | Integrated Graphics |
| EC / KBC | VBG25HV |
| Audio Codec | ALC269 |
| BIOS / SPI Flash | SPI-FLASH |
| Charging IC | BQ24742 |
| Charger Architecture | Battery Charger/Selector |
| Power IC(s) | TPS51220ARSN, VT1316/VT1317, VT357FCX, VT355FCX, MAX15103, TPS62060 |
| RAM Type | DDR3 1333MHz |
| RAM Architecture | 204-PIN DDR3 SODIMM |
| RAM Quantity / Slots | 2 (Channel A, Channel B) |
| Thermal Sensor | EMC1428 |
| Card Reader IC | 4-in-1 Slot |
| USB Hub IC | uPD720200A |
| LAN IC | RTL8111 |
| WiFi / WLAN IC | Intel LEWISVILLE |
| HDMI Level Shifter | FDILVDS |
Sandy Bridge
Integrated Graphics )
VBG25HV
ALC269
BQ24742
MAX15103
TPS51220ARSN
TPS62060
VT1316
VT1317
VT355FCX
VT357FCX
DDR3
EMC1428
4-IN-1 SLOT
UPD720200A
RTL8111
Sandy Bridge
VBG25HV
ALC269
BQ24742
MAX15103
TPS51220ARSN
TPS62060
VT1316
VT1317
VT355FCX
VT357FCX
DDR3
EMC1428
4-IN-1 SLOT
UPD720200A
RTL8111
