Lenovo ThinkPad X395 T495s LCFC Sideswipe Jazz AMD FA391 FA491 NM-C181 Rev 1.0 Schematic
This LC Future Center Sideswipe&Jazz AMD motherboard, revision 1.0 dated March 22, 2019, is built around the FP5 CPU platform. The system management is handled by an IT8186E/FX EC/KBC. Audio processing is provided by an ALC3287-CG codec. Power management and charging are managed by a BQ25700A battery charger and a suite of DC/DC converters including TPS51285B, NB693, NB687, RT8068A, and ISL62771. The board supports DDR4 memory across two channels, MD CHANNEL-A and MD CHANNEL-B. Connectivity includes a LAN46 LAN IC, a WIFI module, a USB HUB, an HDMI RETIMER, and a MEDIA CARD reader. A THERMAL SENSOR is present for temperature monitoring.
A: The EC/KBC is an IT8186E/FX.
A: The audio codec is an ALC3287-CG.
A: The charging IC is a BQ25700A.
Q: What is the CPU platform for this motherboard?
A: The CPU platform is FP5.
| Brand | LC Future Center |
| Project Code | Sideswipe&Jazz AMD |
| Date | Friday, March 22, 2019 |
| CPU Platform | FP5 |
| EC / KBC | IT8186E/FX |
| Audio Codec | ALC3287-CG |
| Charging IC | BQ25700A |
| Power IC(s) | TPS51285B, NB693, NB687, RT8068A, ISL62771 |
| RAM Type | DDR4 |
| RAM Architecture | MD CHANNEL-A, MD CHANNEL-B |
| Card Reader IC | MEDIA CARD |
| USB Hub IC | USB HUB |
| LAN IC | LAN46 |
| WiFi / WLAN IC | WIFI |
| HDMI Level Shifter | HDMI RETIMER |
| Thermal Sensor | THERMAL SENSOR |
