lenovo x200 wistron mocha-1 rev -1
The Wistron Mocha-1 platform, documented under project code 91.47Q01.001 and PCB number 48.47Q01.001, is built around an Intel Penryn SV processor paired with the Intel Cantiga-GM integrated graphics and an Intel ICH9-M southbridge. The system memory architecture consists of two DDR3 SODIMM slots operating at 1067/800MHz in dual-channel configuration. Embedded controller functions are handled by a Renesas H8S/2116 microcontroller in a BG20V package. The platform utilizes an SPI-FLASH for BIOS storage and features an ADP3808 battery charger/selector. Power management is distributed across multiple ICs including the TPS51221, VT1311, BD3550, VT351A, and MAX1510. Thermal monitoring is provided by MAX6694 and LM26 sensors. Connectivity includes a USB2514 USB hub, GLAN BOAZMAN LAN controller, and an ALC262 audio codec. The system also incorporates a WINBOND Super I/O, an ICS9LPRS365 clock generator, and a PI3L500AZFEX HDMI level shifter.
A: The embedded controller is a Renesas H8S/2116 in a BG20V package.
Q: What is the memory architecture of this platform?
A: The platform supports two DDR3 SODIMM slots operating at 1067/800MHz in dual-channel configuration.
A: The charging IC is an ADP3808 configured as a battery charger/selector.
Q: What thermal sensors are present on this board?
A: The board uses a MAX6694 and an LM26 for thermal monitoring.
| Project Code | 91.47Q01.001 |
| Board Number | 48.47Q01.001 |
| Document Number | A3162 |
| Date | Thursday, May 08, 2008 |
| CPU Platform | Penryn SV |
| PCH / Southbridge | Intel ICH9-M |
| GPU Type | Intel Cantiga-GM |
| Graphics Architecture | Integrated Graphics |
| EC / KBC | H8S/2116 |
| EC/KBC Package | BG20V |
| BIOS / SPI Flash | SPI-FLASH |
| Charging IC | ADP3808 |
| Charger Architecture | Battery Charger/Selector |
| Power IC(s) | TPS51221, VT1311, BD3550, VT351A, BD3550, MAX1510 |
| RAM Type | DDR3 |
| RAM Architecture | 1067/800MHz, Channel A, Channel B, Unbuffered, SODIMM |
| Thermal Sensor | MAX6694, LM26 |
| Card Reader IC | R5C811 |
| USB Hub IC | USB2514 |
| LAN IC | GLAN BOAZMAN |
| WiFi / WLAN IC | WLAN Card |
| Audio Codec | ALC262 |
| Super I/O | WINBOND |
| Clock Generator | ICS9LPRS365 |
| HDMI Level Shifter | PI3L500AZFEX |
91.47Q01.001
48.47Q01.001
Penryn
ICH9
Intel Cantiga-GM
Integrated Graphics )
H8S/2116
ADP3808
BD3550
MAX1510
TPS51221
VT1311
VT351A
DDR3
MAX6694, LM26
R5C811
USB2514
ALC262
ICS9LPRS365
Clock Generator
PI3L500AZFEX
91.47Q01.001
48.47Q01.001
Penryn
ICH9
Intel Cantiga-GM
H8S/2116
ADP3808
BD3550
MAX1510
TPS51221
VT1311
VT351A
DDR3
MAX6694, LM26
R5C811
USB2514
ALC262
ICS9LPRS365
Clock Generator
PI3L500AZFEX
