lenovo yoga 3 pro 1370 lcfc nm-a321 rev-1.0 1
This Lenovo BDW CRESENT BAY V1.0 motherboard, documented under number CRDNC137 and dated July 29, 2014, is built around the Broadwell MCP platform. The system memory architecture utilizes LPDDR3 across Channel A and B operating at 1600MHz. Audio processing is handled by an ALC286 codec. For video output, the board integrates a PS8407A HDMI level shifter. Storage and peripheral connectivity includes a GL3213 card reader controller and a WiFi/BT module for wireless connectivity. The board is manufactured by LENOVO PND.
Q: What is the document number for this Lenovo motherboard?
A: The document number is CRDNC137.
A: This motherboard uses the Broadwell MCP platform.
Q: What type of memory is supported?
A: The board supports LPDDR3 memory across Channel A and B at 1600MHz.
Q: What audio codec is used on this board?
A: The audio codec is an ALC286.
| Brand | LENOVO |
| Model | BDW CRESENT BAY V1.0 |
| Motherboard Manufacturer | LENOVO PND |
| Document Number | CRDNC137 |
| Revision | V1.0 |
| Date | Tuesday, July 29, 2014 |
| CPU Platform | Broadwell MCP |
| Audio Codec | ALC286 |
| RAM Type | LPDDR3 |
| RAM Architecture | LPDDR3 Channel A&B |
| RAM Quantity / Slots | 1600MHz |
| HDMI Level Shifter | PS8407A |
| WiFi / WLAN IC | WiFi/BT Module |
| Card Reader IC | GL3213 |
