Missing PP1v2_S3 on 820-000165... any suggestions Master?
Patrick Ribbsaeter Lagadatorumea Staff member Registered Reputation: Oct 13, 2020 #1 Missing PP1v2_S3 on 820-000165... any suggestions Master?
Hosein Asadolahi Staff member Registered Reputation: Oct 13, 2020 #2 LagaDatorUmea said: Missing PP1v2_S3 on 820-000165... any suggestions Master? Click to expand... check u7400 and its circle such as vldoin , v5in , s3 , s5 ... if that ok check page 19 of schematic .
Patrick Ribbsaeter Lagadatorumea Staff member Registered Reputation: Oct 13, 2020 #3 Background info: The motherboard was water damaged and had corrosion around U7400 which I cleaned up. Troubleshoot done: Missing PP1v2_S3 ON VLDOIN... U7400 Pin 12(PP5V_S5) = 5.1v U7400 Pin 16(VDDQ/VTTREF ENABLE) = 3.3v U7400 Pin 17(VTT ENABLE) = 3V SMPS = STUCK at 0.111 AMP - Indication it could be PM_SLP_S4 ? Question: is it U7400 that creates that power rail/voltage? What to check on Page 19... Its only pull-up resistors there for PP1V2_S3.. but that voltage is missing, so what why check that page? Last edited: Oct 13, 2020
Patrick Ribbsaeter Lagadatorumea Staff member Registered Reputation: Oct 13, 2020 #4 UPDATE: I changed the U7400, found a bad trace under the IC. With SMPS I get 0.360 Amp and then drops to 0.036amp after 10 seconds and stays there. With a normal DC charger 85w I get 0.360 Amp and very high FAN spin. No image
