MSI megabook M660 MS-1034 Rev 0A Schematic
The MS-10340.AP revision 0.A motherboard from Micro-Star International is built around the Intel Yonah 479 CPU platform with a 945GM Northbridge and ICH7-M Southbridge. Memory architecture consists of dual-channel DDRII SODIMMs supporting 400/533/667 MHz. The embedded controller is an ENE 3910 KBC. Power management is handled by a MAX1772 charger IC, with additional power regulation from MAX1999, OZ813, ISL6262, and SC486. Networking is provided by a Realtek RTL8111B LAN IC, while audio is managed by a Realtek ALC882D codec. The system includes an OZ711MP card reader controller and an ICS 954310 clock generator. The board was documented on September 22, 2005.
Q: What EC/KBC is used on the MS-10340?
A: The motherboard uses an ENE 3910 KBC.
A: The charging IC is a MAX1772.
Q: What is the memory architecture of the MS-10340?
A: The board supports dual-channel DDRII 400/533/667 MHz via two DDR-SODIMM slots.
Q: What LAN and audio controllers are present?
A: The LAN controller is a Realtek RTL8111B, and the audio codec is a Realtek ALC882D.
| Brand | MSI (Micro-Star International) |
| Model | MS-10340 |
| Motherboard Manufacturer | MICRO-STAR INT'L CO.,LTD. |
| Board Number | MS-10340.AP |
| Revision | 0.A |
| Date | Thursday, September 22, 2005 |
| CPU Platform | Intel Yonah 479 |
| PCH / Southbridge | ICH7-M |
| Northbridge | 945GM |
| EC / KBC | ENE 3910 |
| Charging IC | MAX1772 |
| Power IC(s) | MAX1999, OZ813, ISL6262, SC486 |
| RAM Type | DDRII |
| RAM Architecture | Dual Channel DDRII 400/533/667 MHz |
| RAM Quantity / Slots | 2 (DDR-SODIMM0, DDR-SODIMM1) |
| LAN IC | RTL8111B |
| Card Reader IC | OZ711MP |
| Audio Codec | ALC882D |
| Clock Generator | ICS 954310 |
