MSI MS-9169 Rev 0A 10a 10B 100 Schematic
This MSI MS-9169 motherboard, documented under board number MS-9169 revision 0A, is designed for the Intel P4 Northwood/Prescott 478-pin processor using a uPGA478 socket. The platform is built on the Intel Canterwood-ES MCH and ICH-HR chipset, supporting dual-channel DDR 400/333/266 ECC Unbuffered memory across two DIMM slots. The system utilizes an FWH for BIOS storage and is powered by an Intersil 6556B VRM. Networking is provided by multiple Intel LAN controllers, including the 82551, 82547GI, and 82545GM. The clock generation is handled by an ICS952606 clock generator. The board does not include an EC/KBC, audio codec, charging IC, WiFi, or any dedicated GPU.
A: The board number is MS-9169 with revision 0A.
Q: What CPU platform and socket does this motherboard support?
A: It supports the Intel P4 Northwood/Prescott 478-pin processor using a uPGA478 socket.
Q: What type of memory is supported and how many slots are available?
A: It supports DDR 400/333/266 ECC Unbuffered memory in dual-channel configuration across 2 DIMM slots.
Q: What LAN controllers are used on this motherboard?
A: The board uses Intel 82551, Intel 82547GI, and Intel 82545GM LAN controllers.
Q: What is the clock generator IC used on this board?
A: The clock generator is an ICS952606.
This MSI MS-9169 Rev A motherboard, documented on July 28, 2004, is a custom embedded/server platform designed for FG-300A, FG-400A, and FG-500A systems. It is built around the Intel Canterwood-ES MCH and ICH-HR (Hance Rapids) southbridge, supporting a single Intel P4 Northwood/Prescott 478-pin processor with 400/533/800MHz FSB. Memory architecture consists of two DDR DIMM slots supporting up to 2GB of DDR 400/333/266 ECC Unbuffered memory in dual-channel configuration. The board features a 4-layer PCB and utilizes an ICS952606 clock generator. Networking is extensive, with four Intel 82551 10/100 LAN controllers, one Intel 82547GI Gigabit LAN, and one Intel 82545GM Gigabit LAN, alongside a Forti ASIC BGA and LAN switch options (FG-300A/FG-400A/FG-500A). The VRM is handled by an Intersil 6556B controller. The board uses a Firmware Hub (FWH) for BIOS storage, typical of the era, and does not include an EC/KBC, audio codec, or GPU, as it is a dedicated networking appliance.
This MS-9169 Rev 0A motherboard, dated August 31, 2004, is designed for the FG-300A, FG-400A, and FG-500A platforms. It supports Intel P4 Northwood/Prescott 478-pin processors with a 400/533/800MHz FSB, utilizing the Intel Canterwood-ES MCH and ICH-HR (Hance Rapids) chipset. The board features a Forti ASIC (BGA) for graphics processing. Networking is provided by multiple Intel LAN controllers: the 82551 (CH1~CH4), 82547GI, 82545GM, and an optional 82551QM (CH5) for the FG-500A variant. Memory architecture consists of two DIMM slots supporting up to 2GB of DDR 400/333/266 ECC Unbuffered memory in dual-channel configuration. The clock generator is an ICS952606 in an SSOP48 package, and the VRM is controlled by an Intersil 6556B. The PCB is a 4-layer design.
Q: What is the board number and revision for this motherboard?
A: The board number is MS-9169, revision 0A.
Q: What CPU socket and platform does this motherboard support?
A: It supports the Intel P4 Northwood/Prescott 478-pin processor via a uPGA478 socket.
Q: What chipset is used on this motherboard?
A: The chipset consists of the Intel Canterwood-ES MCH and the ICH-HR (Hance Rapids) southbridge.
Q: What LAN controllers are present on this motherboard?
A: The board uses Intel 82551 (CH1~CH4), Intel 82547GI, Intel 82545GM, and an optional Intel 82551QM (CH5) for the FG-500A variant.
Q: What is the memory configuration for this board?
A: It has 2 DIMM slots supporting up to 2GB of DDR 400/333/266 ECC Unbuffered memory in dual-channel mode.
The MSI MS-9169A motherboard is an Intel Canterwood-ES / ICH-HR chipset-based platform designed for Intel P4 Northwood/Prescott 478-pin processors with 400/533/800MHz FSB. It features dual-channel DDR 400/333/266 ECC Unbuffer memory support via 2 DIMM slots, with a maximum capacity of 2GB. The board integrates multiple LAN controllers including Intel 82551 10/100 LAN, Intel 82544/82545 GB LAN, Intel 82547GI LAN, and Intel 82545GM GB LAN, along with a Forti ASIC and a LAN switch for the FG-500A option. Storage connectivity includes 2 SATA ports, 2 IDE connectors (40-pin and 44-pin), and one CF connector. The clock generation is handled by an ICS952606 clock generator in SSOP48 package. The board is a 4-layer design and includes a Mini-PCI slot, USB 2.0 ports, and serial port support.
A: The board number is MS-9169 with revision A.
A: It supports Intel P4 Northwood/Prescott 478-pin processors with 400/533/800MHz FSB, using a uPGA478 socket.
Q: What memory configuration is supported?
A: The board supports dual-channel DDR 400/333/266 ECC Unbuffer memory with 2 DIMM slots, up to 2GB maximum.
Q: What LAN controllers are integrated on this board?
A: Multiple LAN controllers are used: Intel 82551 10/100 LAN, Intel 82544/82545 GB LAN, Intel 82547GI LAN, and Intel 82545GM GB LAN.
This MSI MS-9169 Rev 0A motherboard, dated October 28, 2004, is designed for the FG-300A, FG-400A, and FG-500A networking/server platforms. It supports Intel P4 Northwood/Prescott 478-pin processors with a 400/533/800 MHz FSB, utilizing the Intel Canterwood-ES MCH and ICH-HR (Hance Rapids) southbridge. Memory architecture consists of two DDR DIMM slots supporting up to 2 GB of DDR 400/333/266 ECC unbuffered memory in dual-channel configuration. Networking is a primary feature, with four Intel 82551 10/100 LAN controllers, one Intel 82547GI Gigabit LAN, and one Intel 82545GM Gigabit LAN. The board also includes a Forti ASIC (BGA) for security acceleration. Power regulation is handled by an Intersil 6556B VRM 10 controller, and clock generation is provided by an ICS952606 clock generator in an SSOP48 package. The board is a 4-layer design.
A: It supports the Intel P4 Northwood/Prescott 478-pin processor in a uPGA478 socket.
Q: What memory type and configuration does this board support?
A: It supports DDR 400/333/266 ECC unbuffered memory in dual-channel configuration, with two DIMM slots for a maximum of 2 GB.
A: The board uses four Intel 82551 10/100 LAN controllers, one Intel 82547GI Gigabit LAN, and one Intel 82545GM Gigabit LAN.
| Brand | MSI |
| Model | MS-9169 |
| Motherboard Manufacturer | Micro-Star Int'l Co., Ltd. |
| Board Number | MS-9169 |
| Revision | 0A |
| Date | Tuesday, June 08, 2004 |
| CPU Platform | Intel P4 Northwood/Prescott 478-pin |
| CPU Socket | uPGA478 |
| PCH / Southbridge | ICH-HR |
| GPU Type | None (No dGPU) |
| Graphics Architecture | None (No dGPU) |
| EC / KBC | None |
| Audio Codec | None |
| BIOS / SPI Flash | FWH |
| Charging IC | None |
| Charger Architecture | None |
| Power IC(s) | Intersil 6556B |
| RAM Type | DDR 400/333/266 ECC Unbuffer |
| RAM Architecture | Dual Channels |
| RAM Quantity / Slots | 2 DIMMs |
| LAN IC | Intel 82551, Intel 82547GI, Intel 82545GM |
| WiFi / WLAN IC | None |
| Card Reader IC | None |
| USB Hub IC | None |
| HDMI Level Shifter | None |
| Thermal Sensor | None |
| Clock Generator | ICS952606 |
| Document Number | MS-91690A |
| Brand | MSI |
| Model | MS-9169 |
| Revision | A |
| Date | Wednesday, July 28, 2004 |
| PCH / Southbridge | ICH-HR (Hance Rapids) |
| GPU Type | None (Server/Embedded) |
| EC / KBC | None (Server/Embedded) |
| BIOS / SPI Flash | FWH (Firmware Hub) |
| Charging IC | None (Server/Embedded) |
| RAM Type | DDR 400/333/266 ECC Unbuffered |
| LAN IC | Intel 82551 (x4), Intel 82547GI, Intel 82545GM |
| WiFi / WLAN IC | None (Server/Embedded) |
| Audio Codec | None (Server/Embedded) |
| Card Reader IC | None (Server/Embedded) |
| USB Hub IC | None (Server/Embedded) |
| HDMI Level Shifter | None (Server/Embedded) |
| Thermal Sensor | None (Server/Embedded) |
| Power IC(s) | Intersil 6556B (VRM 10) |
| Clock Generator | ICS952606 (SSOP48) |
| MCH / Northbridge | Canterwood-ES |
| Forti ASIC | Forti_ASIC (BGA) |
| LAN Switch | FG-300A / FG-400A / FG-500A |
| Title | FG-300A / FG-400A / FG-500A Schematics |
| PCB Layers | 4 |
| Brand | MSI |
| Model | FG-300A / FG-400A / FG-500A |
| Revision | 0A |
| Date | Tuesday, August 31, 2004 |
| GPU Type | Forti ASIC (BGA) |
| LAN IC | Intel 82551 (CH1~CH4) |
| LAN IC | Intel 82547GI |
| LAN IC | Intel 82545GM |
| LAN IC | Intel 82551QM (CH5, FG-500A option) |
| VRM Controller | Intersil 6556B |
| PCB Layer Count | 4-layer board |
| Brand | MSI (Micro-Star Int'l Co., Ltd.) |
| Model | MS-9169 |
| Revision | A |
| Date | Tuesday, September 07, 2004 |
| GPU Type | None (discrete GPU not present) |
| LAN IC | [URL="https://dr-bios.com/components/lan-ic/82551/"]Intel 82551 10/100 LAN[/URL], Intel 82544/82545 GB LAN, [URL="https://dr-bios.com/components/lan-ic/82547gi/"]Intel 82547GI LAN[/URL], [URL="https://dr-bios.com/components/lan-ic/82545gm/"]Intel 82545GM GB LAN[/URL] |
| Clock Generator | ics952606-ssop48/"]ICS952606_SSOP48[/URL] |
| Brand | MSI |
| Revision | 0A |
| Date | Thursday, October 28, 2004 |
| GPU Type | None (Server/Networking) |
| LAN IC | Intel 82551 (CH1~CH4), Intel 82547GI, Intel 82545GM |
| Charging IC | None (Desktop/Server) |
| Crystal | 14.318 MHz (Y1) |
MS-9169
Northwood
Prescott
None (No dGPU)
6556B
DDR
UNBUFFER
82545GM
82547GI
82551
ICS952606
Clock Generator
Embedded)
None (Server
UNBUFFERED
FG-300A
FG-400A
FG-500A
Forti ASIC
82551QM (CH5
82544/82545 GB LAN
82545GM GB LAN
82547GI LAN
82551 10/100 LAN
ICS952606_SSOP48
Clock Generator
Networking)
MS-9169
Northwood
Prescott
None (No dGPU)
6556B
DDR
UNBUFFER
82545GM
82547GI
82551
ICS952606
Clock Generator
Embedded)
None (Server
UNBUFFERED
FG-300A
FG-400A
FG-500A
Forti ASIC
82551QM (CH5
82544/82545 GB LAN
82545GM GB LAN
82547GI LAN
82551 10/100 LAN
ICS952606_SSOP48
Clock Generator
Networking)
