Technical Support Please I need help on one board Dell latitude 3340
Ismail-U50
please I need a help one board Dell latitude
3340 if i on it now in 2-3 seconds it goes off and battery light also flash on and then goes off too. So any idea solution to that please, in case I forget to say this, have tried to recode the bios but still the same. So any help please
Hello
Did you test the motherboard? Are the necessary voltages for the motherboard present?
If all the voltages are present, first program the BIOS and replace parts such as RAM and CPU, and finally, you should look for problems on the ICs and chipsets on the motherboard.
Patrick Ribbsaeter
Lagadatorumea
Can u please post some voltages for us?
U can start by checking all the coils, check if u get any voltage on them when switching on and off.. also check for short on all coils.. and please post here. thanks
