Sony MB MBX-195 Schematic
The FOXCONN M850 Main Board_8L (Board Number M850-1-01, Revision 1.0, dated April 8, 2009) is a motherboard designed by HON HAI Precision Ind. Co., Ltd. It supports Penryn, Celeron, and Merom processors via a Micro-FCPGA-478 socket. The platform is built around the Intel Cantiga PM/GM Northbridge and ICH9-M Southbridge, with an AMD M92-S2 XT discrete GPU using GDDR3 VRAM. System memory consists of two 200-pin SO-DIMM slots supporting DDR2 at 800 MHz. The embedded controller is a Winbond WPCE775L, and the BIOS is stored on a 16M bit SPI flash ROM. Audio is handled by a Realtek ALC262 codec, and networking is provided by a Marvell 88E8057 Gig
| Brand | FOXCONN |
| Motherboard Manufacturer | HON HAI Precision Ind. Co., Ltd. / CCPBG - R&D Division / FOXCONN |
| Project Code | M850 Main Board_8L |
| Board Number | M850-1-01 |
| Date | Wednesday, April 08, 2009 |
| CPU Platform | Penryn / Celeron / Merom |
| CPU Socket | Micro-FCPGA-478 (478-pin socket P) |
| PCH / Southbridge | ICH9-M |
| Northbridge | Cantiga PM/GM |
| GPU Type | AMD M92-S2 XT |
| Graphics Architecture | GDDR3 |
| EC / KBC | Winbond WPCE775L |
| Audio Codec | Realtek ALC262 |
| BIOS / SPI Flash | Flash BIOS 16M bit SPI |
| Charging IC | TI BQ24751 |
| Charger Architecture | TI CHARGER |
| Power IC(s) | ISL6262A, APL5913, SC411, TPS51116, TPS51125 |
| RAM Type | DDR(II) |
| RAM Architecture | SO-DIMM 200 pin 800 MHZ |
| Card Reader IC | RICOH R5C833 |
| LAN IC | Marvell 88E8057 |
| WiFi / WLAN IC | CK505 SL28541BQC |
| HDMI Level Shifter | HDMI |
| Thermal Sensor | G781, EMC1402-2-ACZL |
| Amplifier | GMT G1431 |
| Modem | MDC 1.5 Modem |
| Clock Generator | CK505 SL28541BQC |
| DC/DC Controller | ISL6262A, APL5913, SC411, TPS51116, TPS51125 |
| VRAM | GDDR3 VRAM 32M X 32b X 4 |
| Alternate Board Number | 1P-0094J00-8011(IRIS), 1P-0094500-8011(HANNSTAR), 1P-1094J01-8011(IRIS), 1P-1094501-8011(HANNSTAR), 1P-1094J00-8011(IRIS), 1P-1094500-8011(HANNSTAR) |
