sony quanta gc8.gc9 calpella uma 990304 1
This Quanta LD-Note Calpella UMA motherboard is built on the Diamond-3 Intel Calpella Platform with UMA GFX, featuring an Intel Arrandale CPU on an rPGA 989 socket paired with the Ibex Peak-M Intel 5 Series Express Chipset. The system utilizes dual-channel DDR3 SODIMM memory supporting 800/1067 MHz at 1.5V. Embedded controller functionality is provided by an ITE8502 in a QFN32 package. The audio subsystem is driven by an ALC269Q codec, while networking is handled by an RTL8111DL LAN controller. The charging architecture employs an ISL88731 charger IC, with power regulation managed by ISL6237IRZ-T, ISL62882, MAX17028, RT8204, and TPS51116REGR. The board includes PS8101 for HDMI level shifting and an R5538 card reader controller. BIOS storage is split across a 2Mbyte and a 4Mbyte SPI flash.
A: The motherboard uses an ITE8502 EC/KBC in a QFN32 package.
Q: What is the charging architecture of this motherboard?
A: The charging architecture uses an ISL88731 charger IC with AC-DC battery DC-DC power delivery.
Q: What BIOS flash configuration is present?
A: The board uses two SPI flash devices: one 2Mbyte and one 4Mbyte.
Q: What memory configuration does this motherboard support?
A: The motherboard supports dual-channel DDR3 800/1067 MHz at 1.5V via two SODIMM slots.
| Model | LD-Note Calpella UMA |
| Motherboard Manufacturer | Quanta Computer Inc. |
| Project Code | LD-Note Calpella UMA |
| Date | Thursday, March 04, 2010 |
| CPU Platform | Intel Calpella Platform with UMA GFX |
| Platform Alias | Diamond-3 Intel Calpella Platform with UMA GFX |
| CPU Socket | rPGA 989 |
| PCH / Southbridge | Ibex Peak-M Intel(R) 5 Series Express Chipset |
| GPU Type | UMA |
| Graphics Architecture | UMA |
| EC / KBC | ITE8502 |
| EC/KBC Package | QFN32 |
| Audio Codec | ALC269Q |
| BIOS / SPI Flash | FLASH 2Mbyts, FLASH 4Mbyts |
| Charging IC | ISL88731 |
| Charger Architecture | AC-DC Battery DC-DC |
| Power IC(s) | ISL6237IRZ-T, ISL62882, MAX17028, RT8204, TPS51116REGR |
| RAM Type | DDR3 |
| RAM Architecture | Dual Channel DDR3 800/1067 1.5V |
| RAM Quantity / Slots | DDR3 - SODIMM0, DDR3 - SODIMM1 |
| Card Reader IC | R5538 |
| LAN IC | RTL8111DL |
| WiFi / WLAN IC | MINI-CARD WLAN/WiMAX |
| HDMI Level Shifter | PS8101 |
