sony vaio pcg-361n quanta_ak1_rev1a schematic
sony vaio pcg-361n=1=quanta_ak1_rev1a.pdf
The Quanta AK1 Main Board revision 1A is an Intel Dothan platform motherboard dated October 12, 2004. The system architecture is built around the Montara-GM Northbridge and the 82801DBM Southbridge, supporting DDR 266/333 memory via two SO-DIMM slots. Embedded controller functionality is provided by the NS PC97551. The audio subsystem utilizes the ALC203 codec, while wired networking is handled by the RTL8100CL LAN IC. Power management and charging are managed by a combination of ICs including the MAX1907, MAX1632, MAX1715, TPS51100, APL5912, and the MAX1873 charging IC. System clock generation is handled by the ICS950810 clock generator.
A: The embedded controller is the NS PC97551.
A: The charging IC is the MAX1873.
Q: What power management ICs are present on this board?
A: The power ICs include the MAX1907, MAX1632, MAX1715, TPS51100, and APL5912.
A: The board supports DDR 266/333 memory via two SO-DIMM slots.
| Brand | QUANTA COMPUTER |
| Board Number | AK1 Main Board |
| Revision | 1A |
| CPU Platform | Intel Dothan |
| Northbridge | Montara-GM |
| Southbridge | 82801DBM |
| EC / KBC | NS PC97551 |
| Audio Codec | ALC203 |
| LAN IC | RTL8100CL |
| Charging IC | MAX1873 |
| Power IC(s) | MAX1907, MAX1632, MAX1715, TPS51100, APL5912 |
| RAM Type | DDR 266/333 |
| RAM Architecture | SO-DIMM 1/2 |
| Clock Generator | ICS950810 |
