sony vaio pcg-6161 quanta_ne7_uma_rev3a schematic
sony vaio pcg-6161=1=quanta_ne7_uma_rev3a.pdf
This Quanta Computer motherboard, documented under number 3A revision B1 dated March 20, 2010, is built around the AMD S1G4 CPU platform with an RS880M GPU and SB820M southbridge. The system uses an NPCE781 embedded controller and a Realtek ALC269Q-VB5-GR audio codec. Networking is handled by a Realtek RTL8111E LAN IC, while storage connectivity includes a Realtek RTL8111E for LAN and an RTK RTS5186 card reader controller. Power management is managed by an ISL6252A charger IC, with voltage regulation provided by ISL6265A, PM6686, and OZ8116LN power ICs. The board supports two DDR3 SODIMM slots for memory expansion and includes an 802.11bgn WLAN module for wireless connectivity.
Q: What embedded controller is used on this motherboard?
A: The motherboard uses an NPCE781 EC/KBC.
A: The audio codec is a Realtek ALC269Q-VB5-GR.
A: The charging IC is an ISL6252A.
Q: What power ICs are used on this motherboard?
A: The power ICs include ISL6265A, PM6686, and OZ8116LN.
Q: What card reader controller is used on this motherboard?
A: The card reader controller is an RTK RTS5186.
| Brand | QUANTA COMPUTER |
| Document Number | 3A |
| Revision | B1 |
| Date | Saturday, March 20, 2010 |
| CPU Platform | AMD S1G4 CPU |
| PCH / Southbridge | SB820M |
| GPU Type | RS880M |
| EC / KBC | NPCE781 |
| Audio Codec | Realtek ALC269Q-VB5-GR |
| LAN IC | Realtek RTL8111E |
| Card Reader IC | RTK RTS5186 |
| Charging IC | ISL6252A |
| Power IC(s) | ISL6265A, PM6686, OZ8116LN |
| RAM Type | DDR3 SODIMM X2 |
| WiFi / WLAN IC | 802.11bgn WLAN Module |
