toshiba satellite 1000-1100 compal_la-1521_rev1.0a schematic
toshiba satellite 1000-1100=1=compal_la-1521_rev1.0a.pdf
The Compal LA-1521 motherboard, documented under document number 4012291B revision 1.0A dated 07/30 2002, is built around the Intel Mobile P4 uFCBGA/uFCPGA Northwood Celeron platform. The chipset consists of the MCH-M (845MZ) northbridge paired with the ICH3-M southbridge. Graphics are handled by an ATI M6-C GPU with 16MB of dedicated DDR VRAM. The embedded controller is an NS PC87591S, which is programmable via the EC JTAG connector JP22. System memory is provided by two DDR SO-DIMM slots. The audio codec is an ALC202, and the LAN controller is an RTL8100BL. The charging architecture utilizes a Smart Battery configuration managed by the OZ6933B charging IC. Thermal monitoring is handled by the MAX6654MEE sensor, and the clock generator is an ICS9508-05.
A: The board number is LA-1521, and the revision is 1.0A.
A: Yes, the EC/KBC (NS PC87591S) is programmable via the EC JTAG connector JP22.
Q: What is the charging architecture used on this motherboard?
A: The charging architecture uses a Smart Battery configuration with an OZ6933B charging IC.
Q: What type of memory and how many slots are available?
A: The motherboard supports DDR memory via two SO-DIMM slots.
| Model | LA-1521 |
| Motherboard Manufacturer | Compal Electronics, inc. |
| Board Number | LA-1521 |
| Revision | REV 1.0A |
| Date | 07/30 2002 |
| Document Number | 4012291B |
| CPU Platform | Intel Mobile P4 uFCBGA/uFCPGA Northwood Celeron |
| PCH / Southbridge | ICH3-M |
| GPU Type | ATI M6-C |
| Graphics Architecture | M6-C (16MB VRAM) |
| EC / KBC | NS PC87591S |
| EC/KBC Programmable | EC JTAG Connector (JP22) |
| Audio Codec | ALC202 |
| Charging IC | OZ6933B |
| Charger Architecture | Smart Battery |
| RAM Type | DDR |
| RAM Architecture | SO-DIMM x 2 |
| Thermal Sensor | MAX6654MEE |
| Card Reader IC | TPA0132 |
| LAN IC | RTL8100BL |
| Super I/O | LPC47N227 |
| Clock Generator | ICS9508-05 |
LA-1521
ICH3-M
ATI-M6-C
M6-C (16MB VRAM)
NS PC87591S
ALC202
OZ6933B
DDR
MAX6654MEE
TPA0132
RTL8100BL
LPC47N227
Super I/O
ICS9508-05
Clock Generator
LA-1521
ICH3-M
ATI-M6-C
M6-C (16MB VRAM)
NS PC87591S
ALC202
OZ6933B
DDR
MAX6654MEE
TPA0132
RTL8100BL
LPC47N227
Super I/O
ICS9508-05
Clock Generator
