Schematic toshiba satellite a505 inventec chelsea 10mg cs10mg 6050a2251001 schematic
toshiba satellite a505=1=inventec chelsea 10mg cs10mg 6050a2251001.pdf
BrandINVENTEC
ModelChelsea 10MG
Motherboard ManufacturerINVENTEC
Project CodeChelsea 10MG
Board Number6050A2250-0-M
RevisionREV
Date19-Feb-2009
CPU PlatformPenryn
CPU SocketSocket P
PCH / SouthbridgeICH9-M
GPU TypeCantiga
Graphics ArchitectureCantiga
EC / KBCWINBOND
Audio CodecALC 272
Charging ICTI_BQ24721C_QFN_32P
Charger ArchitectureSystem Charger &
RAM TypeDDR2
RAM ArchitectureDDR2 Interface
RAM Quantity / SlotsDDR2 DIMM0, DDR2 DIMM1
Card Reader ICRICOH_R5U230
LAN ICRealtek RTL8111
WiFi / WLAN ICRealtek
HDMI Level ShifterHDMI CONN & CIR
The Inventec Chelsea 10MG motherboard, documented under board number 6050A2250-0-M, is a Penryn Socket P platform paired with the ICH9-M southbridge and Cantiga integrated graphics. The system memory architecture is DDR2, supported by two DIMM slots (DDR2 DIMM0 and DDR2 DIMM1). The embedded controller is a Winbond KBC, and the audio subsystem is managed by a Realtek ALC272 codec. Power management and charging are handled by a TI BQ24721C QFN-32P charger IC. The board integrates a Realtek RTL8111 LAN controller, a Ricoh R5U230 card reader, and a Realtek WLAN module. The HDMI interface is supported via a dedicated connector and CIR circuitry. The schematic revision is dated 19-Feb-2009.
Q: What is the board number for this Inventec Chelsea 10MG motherboard?
A: The board number is 6050A2250-0-M.
Q: What CPU platform and socket does this motherboard use?
A: The CPU platform is Penryn, and the socket is Socket P.
Q: What is the charging IC used on this motherboard?
A: The charging IC is a TI BQ24721C in a QFN-32 package.
A: The audio codec is a Realtek ALC272.
Q: What is the embedded controller (EC/KBC) on this motherboard?
A: The embedded controller is a Winbond KBC.
  • Toshiba Satellite A505=1=Inventec Chelsea 10MG CS10MG 6050A2251001.zip
