toshiba satellite c660 compal-la-6842p_rev0.2 schematic
toshiba satellite c660=1=compal-la-6842p_rev0.2.pdf
The Compal PWWAA LA-6842P Rev 0.2 motherboard, dated 2010-07-22, is built around the Intel Arrandale processor platform paired with the Intel Ibex Peak HM55 PCH. System management is handled by an ENE KB926 E02 embedded controller with a dedicated EC ROM. The audio subsystem features a Realtek ALC259-GR High Definition Audio Codec. Networking is provided by a Realtek RTL8105E-GR 10/100M Ethernet controller. Memory configuration consists of two DDRIII SO-DIMM slots supporting DDRIII 800/1066 MT/s. The board includes a Realtek RTS5137 external dual-channel card reader controller and an RTM890N-631-GRT clock generator. The BIOS is stored on a SPI ROM, while the EC firmware resides on a separate EC ROM.
A: The motherboard uses an ENE KB926 E02 embedded controller.
A: The audio codec is a Realtek ALC259-GR.
A: The LAN IC is a Realtek RTL8105E-GR 10/100M Ethernet controller.
A: The motherboard supports two DDRIII SO-DIMM slots for DDRIII 800/1066 MT/s memory.
| Model | PWWAA LA-6842P |
| Project Code | PWWAA |
| Board Number | LA-6842P |
| Revision | 0.2 |
| Date | 2010-07-22 |
| CPU Platform | Intel Arrandale |
| PCH / Southbridge | Intel Ibex Peak HM55 |
| EC / KBC | ENE KB926 E02 |
| Audio Codec | ALC259-GR |
| EC Flash / ROM | EC ROM |
| RAM Type | DDRIII-SO-DIMM |
| LAN IC | RTL8105E-GR |
| Card Reader IC | RTS5137 |
| Clock Generator | RTM890N-631-GRT |
