toshiba vskaa ls-9862p r01 20121203
This Compal Electronics, Inc. document covers the LS-9862P motherboard, project code VSKAA, with board number DA2000WU000. The schematic is revision 0.1, dated 2012/09/28, and the PCB revision is 0.3. The document includes a power button and power LED interface, with a notice that the ON/OFFBTN# signal does not have a pull-high resistance on the motherboard. The power LED has a forward voltage of 2.55 to 3.15V and a maximum current of 20mA, with the LED resistance also not located on the motherboard. The schematic details the power button switch (SW_TJG-533-V-T-R_6P) and associated ESD protection components.
Q: What is the board number for this Compal LS-9862P motherboard?
A: The board number is DA2000WU000.
Q: What is the PCB revision for the LS-9862P?
A: The PCB revision is 0.3.
Q: Where are the pull-high resistance and LED resistance located for the power button and power LED?
A: The pull-high resistance for the ON/OFFBTN# signal and the LED resistance for the power LED are not on the motherboard.
| Model | LS-9862P |
| Project Code | VSKAA |
| Board Number | DA2000WU000 |
| Revision | 0.1 |
| Date | 2012/09/28 |
| PCB Name | LS-9862P |
| PCB Revision | 0.3 |
