Schematic acer chromebook c730 cb3-111 quanta zhq schematic
BrandQuanta Computer Inc.
Project CodeZHQ
Revision1A
DateThursday, July 03, 2014
CPU PlatformIntel Bay Trail-M
CPU ModelN2820 2.13G SR1SG (FCBGA)
EC / KBCTM4E1G31H6ZRB
EC/KBC PackageBGA-157
Audio CodecMAX98090
BIOS / SPI Flash1.8V BIOS + TXE SPI ROM (64Mb)
Charging ICBQ24715
Charger ArchitectureBQ24715 Batery Charger
Power IC(s)TPS51216, ISL95833HRTZ-T, TPS51225, NB671GQ-Z
RAM TypeDDR3L
RAM ArchitectureDDR3L 1600 Memory down
Card Reader ICGL852G-OHG12
USB Hub ICSLB9655TT1.2
WiFi / WLAN ICWLAN / BT Combo NGFF
TPM[URL="https://dr-bios.com/components/tpm/slb9655tt1-2/"]SLB9655TT1.2 FW4.32 GOOG[/URL]
Thermal SensorTMP432
Video CodecGL852G-OHG12
eMMCMMC W25Q64FW SSIG CCD Integrated
This Quanta Computer Inc. ZHQ project motherboard is built on the Intel Bay Trail-M platform, featuring an N2820 2.13G SR1SG CPU in an FCBGA 1170 package. The system utilizes DDR3L 1600 memory in a down configuration. The embedded controller is a TM4E1G31H6ZRB in a BGA-157 package. The BIOS and TXE firmware are stored on a 1.8V SPI ROM with a capacity of 64Mb. Power management is handled by a BQ24715 battery charger, along with power ICs including TPS51216, ISL95833HRTZ-T, TPS51225, and NB671GQ-Z. The audio subsystem is managed by a MAX98090 codec. Connectivity includes a WLAN/BT Combo NGFF module, a GL852G-OHG12 video codec and card reader, and an SLB9655TT1.2 USB hub and TPM module. Thermal monitoring is provided by a TMP432 sensor.
A: The motherboard uses a 1.8V BIOS + TXE SPI ROM with a capacity of 64Mb.
Q: What EC/KBC chip is used on this motherboard?
A: The EC/KBC is a TM4E1G31H6ZRB in a BGA-157 package.
A: The motherboard uses DDR3L 1600 memory in a down configuration.
A: The charging IC is a BQ24715 battery charger.
  • Acer Chromebook C730 CB3-111=Quanta ZHQ.pdf
