Acer Chromebook C731 Quanta ZHM Rev A1A Schematic
This Quanta ZHM Chromebook motherboard is built on the Intel Braswell platform with a TDP of 6 Watts. The system memory consists of 4 pieces of LPDDR3 soldered down. The embedded controller is a Microchip MEC1322-LZYP in a DQFN132 package, communicating via LPC and SPI interfaces. The BIOS SPI flash is a Winbond W25Q64FW with a capacity of 64Mb. Power management is handled by a PMIC RT5067, with additional voltage regulation from RT7290, RT7291, and RT9610 MOSFETs paired with CSD87381P. The charging solution is a BQ24770 NVDC battery charger. Audio is provided by a Realtek ALC5650 codec, and thermal monitoring is managed by a TMP432 sensor. The board also integrates a REALTEK audio codec in a QFN-48 package and supports a WLAN/BT combo module.
A: The BIOS SPI flash is a Winbond W25Q64FW with a capacity of 64Mb.
Q: What EC/KBC chip is used on this motherboard?
A: The embedded controller is a Microchip MEC1322-LZYP in a DQFN132 package.
Q: What is the charging architecture of this motherboard?
A: The charging solution is a BQ24770 NVDC battery charger.
A: The system uses 4 pieces of LPDDR3 memory soldered down.
| Model | ZHM Chromebook |
| Motherboard Manufacturer | Quanta Computer Inc. |
| Project Code | ZHM |
| Document Number | ZHM441 |
| Revision | A1A |
| Date | Monday, December 12, 2016 |
| CPU Platform | Intel Braswell |
| EC / KBC | MEC1322-LZYP |
| EC/KBC Package | DQFN132 |
| Audio Codec | ALC5650 |
| BIOS / SPI Flash | W25Q64FW |
| BIOS Flash Capacity | 64Mb |
| Charging IC | BQ24770 |
| Charger Architecture | NVDC Battery Charger |
| Power IC(s) | RT5067, RT7290, RT7291, RT9610, CSD87381P |
| RAM Type | LPDDR3 |
| RAM Architecture | Memory down 4Pcs |
| Thermal Sensor | TMP432 |
| LAN IC | RT7291 |
| WiFi / WLAN IC | WLAN / BT Combo |
