Technical Support ASUS X555LD REV 3.6 hdmi not working
Ipart
Hi
the computer works properly on the lcd screen. However, it does not display an image through the HDMI connection. The system shows a second monitor with the correct model but only a black screen on the monitor. I checked the HDMI socket, fuses. Does that mean the CPU is damaged? Can I check something else to verify it?
F4801 5V is present
on Q4803 1-3.3V 2-3V 3-about 4.7V
Hi
F4801 5V is present
are you sure from software problems ?? like windows or driver .... . are you test with windows live ??
if you test all of theme , yes ( maybe pch have problem )
