Schematic fujitsu siemens esprimo v5505 c45 c46 rev -1 schematic
BrandWistron Corporation
Project CodeC45 Project code: 91.4U501.001 / C46 Project code: 91.4V001.001
Board NumberPCB Number : 06254
Revision-1
DateTuesday, April 24, 2007
CPU PlatformMobile CPU Merom 479 2G/2.33G
PCH / SouthbridgeICH8M
GPU TypeATI M71/M72
EC / KBCWinbond WPC8763L
Audio CodecCX20549
BIOS / SPI FlashSPI I/F
Charging ICMAX8725
Power IC(s)TPS51120 / SC411 / APL5915 / TPS5110 / ISL6262
RAM TypeDDR2 533/667 MHz
RAM ArchitectureDDR Memory I/F
LAN ICRTL8111B
WiFi / WLAN IC802.11/a/b/g/n
Card Reader ICRTS5158
USB Hub ICGL850G
This Wistron C45/C46 motherboard, dated April 24, 2007, with PCB number 06254 revision -1, is designed for the Mobile CPU Merom 479 platform. The platform utilizes an ICH8M southbridge and features an ATI M71/M72 discrete GPU. System memory is DDR2 operating at 533/667 MHz. The embedded controller is a Winbond WPC8763L, and the audio codec is a CX20549. Power management is handled by a combination of ICs including the MAX8725 charger, TPS51120, SC411, APL5915, TPS5110, and ISL6262. Networking is provided by a Realtek RTL8111B Gigabit LAN controller, and wireless connectivity supports 802.11a/b/g/n standards. A Realtek RTS5158 card reader and a Genesys GL850G USB hub are also integrated. The BIOS is accessed via a Serial Peripheral Interface (SPI).
A: The PCB number is 06254. The project codes are 91.4U501.001 for C45 and 91.4V001.001 for C46.
A: The embedded controller is a Winbond WPC8763L.
A: The charging IC is a MAX8725.
Q: What is the CPU and PCH platform for this motherboard?
A: The CPU platform is a Mobile CPU Merom 479, and the PCH is an ICH8M.
  • Fujitsu siemens esprimo V5505=C45 C46 Rev -1.pdf
