Gigabyte H410M S2H V2 Rev 1.1 1.01 Schematic
The Gigabyte H410M S2H V2 motherboard, project code U19148-0 and board number 9MH41MS2H-00-11B, is based on the Intel LGA1200 platform supporting Comet Lake processors with an H470 PCH. The board utilizes a single SPI BIOS flash with a capacity of 128Mb. System management is handled by an ITE 8688 LPC I/O controller. Audio is provided by a Realtek ALC897 VA2 codec, and networking is managed by a Realtek RTL8125BS (I219V) LAN IC. The memory architecture consists of two DDR4 DIMM slots.
A: The board uses a single SPI BIOS flash with a capacity of 128Mb.
A: The board uses an ITE 8688 LPC I/O controller.
Q: What is the audio codec on this motherboard?
A: The audio codec is a Realtek ALC897 VA2.
A: The board uses a Realtek RTL8125BS (I219V) LAN IC.
The Gigabyte GA-H410M S2H V2 motherboard, revision 1.1, is built around the Intel LGA1200 (Comet Lake) platform with an H410 PCH. The board uses an ITE 8688 LPC I/O controller and features a single SPI BIOS flash with a capacity of 128Mb. Audio is handled by a Realtek ALC897 VA2 codec, while networking is provided by a Realtek RTL8125BS (I219V) LAN IC and a Realtek RTL8111K WLAN IC. Memory support includes two DDR4 DIMM slots. The board integrates a Realtek RTD2168 DP to VGA converter for display output. The project code is U19148-0, with a board number of 9MH41MS2H-00-11B.
A: The motherboard uses an ITE 8688 LPC I/O controller.
A: The LAN IC is a Realtek RTL8125BS (I219V).
| Brand | Gigabyte Technology |
| Model | H410M S2H V2 |
| Motherboard Manufacturer | Gigabyte Technology |
| Project Code | U19148-0 |
| Board Number | 9MH41MS2H-00-11B |
| Revision | 1.01 |
| Date | Friday, January 15, 2021 |
| CPU Platform | Intel LGA1200 (Comet Lake) |
| PCH / Southbridge | H470 |
| EC / KBC | ITE 8688 |
| Audio Codec | Realtek ALC897 VA2 |
| BIOS / SPI Flash | SPI BIOS (128Mb) |
| LAN IC | Realtek RTL8125BS (I219V) |
| RAM Type | DDR4 |
| RAM Architecture | DDR4 DIMM X 1, DDR4 DIMM X 1 |
| Model | GA-H410M S2H V2 |
| Revision | 1.1 |
| Date | Friday, April 16, 2021 |
| Document Number | Custom |
| PCH / Southbridge | H410 |
| RAM Type | DDR4 |
| RAM Quantity / Slots | DIMM X 2 |
| GPU Type | DP-RGB (RTD2168) |
| WiFi / WLAN IC | Realtek RTL8111K |
