hp 6530b 6730b dd08 6050a2154101-mb rev ax3 pv 0310
The INVENTEC AX3 motherboard, documented under board number 369A3CSDD08 and revision REV31, is designed for the Cantiga/Penryn CPU platform paired with the ICH9-M southbridge. Graphics are handled by a discrete NV100PAD GPU. The system supports two DDR2 SO-DIMM slots. Power management is distributed across multiple ICs including the ADP3208, ADP3209, TPS51117, TPS51120, SC412A, and G2997, with charging controlled by a BQ24740 IC. The embedded controller options include KBC1070 or KBC1091. Audio is managed by an AZALIA_1984A codec. Networking is provided by a BCM5784 LAN IC, with wireless support for WLAN/WiMAX and WWAN/Robson modules. The system includes a Super I/O controller, an ADT7421 thermal sensor, and a DVI controller for external display output.
Q: What EC/KBC options are available on this motherboard?
A: The motherboard supports either a KBC1070 or KBC1091 embedded controller.
Q: What is the charging IC used on this motherboard?
A: The charging IC is a BQ24740.
A: The motherboard supports DDR2 memory via two SO-DIMM slots.
Q: What is the LAN IC on this motherboard?
A: The LAN IC is a BCM5784.
| Brand | INVENTEC |
| Model | AX3 |
| Motherboard Manufacturer | INVENTEC |
| Project Code | AX3 |
| Board Number | 369A3CSDD08 |
| Revision | REV31 |
| Date | 14-Feb-2008 |
| CPU Platform | Cantiga / Penryn |
| PCH / Southbridge | ICH9-M |
| GPU Type | Discrete |
| Graphics Architecture | NV100PAD |
| EC / KBC | KBC1070 / KBC1091 |
| Audio Codec | AZALIA_1984A |
| BIOS / SPI Flash | FWH/SPI/HDD PROTECTION |
| Charging IC | BQ24740 |
| Charger Architecture | System Charger & DC/DC |
| Power IC(s) | ADP3208, ADP3209, TPS51117, TPS51120, SC412A, G2997 |
| RAM Type | DDR2 |
| RAM Architecture | DDR2 _SODIMM0, DDR2 _SODIMM1 |
| Card Reader IC | 7 IN 1 CONTROLLER(TT), 7 IN 1 CONTROLLER(TS) |
| LAN IC | BCM5784 |
| WiFi / WLAN IC | WLAN/WiMAX, WWAN/Robson, WLAN/Robson |
| Super I/O | Super I/O |
| Thermal Sensor | ADT7421 |
| USB Hub IC | SMSC USB2228 |
| HDMI Level Shifter | DVI CONTROLLER |
| Document Number | 369A3CSDD08 |
AX3
369A3CSDD08
Cantiga
Penryn
ICH9
NV100PAD
KBC1070
KBC1091
AZALIA_1984A
BQ24740
ADP3208
ADP3209
G2997
SC412A
TPS51117
TPS51120
DDR2
7 IN 1 CONTROLLER
BCM5784
ADT7421
USB2228
AX3
369A3CSDD08
Cantiga
Penryn
ICH9
NV100PAD
KBC1070
KBC1091
AZALIA_1984A
BQ24740
ADP3208
ADP3209
G2997
SC412A
TPS51117
TPS51120
DDR2
7 IN 1 CONTROLLER
BCM5784
ADT7421
USB2228
