Technical Support IC 51125 Very Hot!!! in a Samsung Notebook RV-510
Brandon coder
Never a good idear to bridge a mosfet.
. Better to put Amy other one. That is same kind. N - chanel or P Chanel.
Pwm circuit ..
19v enter... high side mosfet turns on for 0.2 second.. t mosfet turn off voltage goes negative then repats.
That chip turn on and of the two gates..
So. Mosfet shored..
I would pull one leg of inductor and check which side short comeing before voltage injection.
Test mosfets fir short then if shirt replace then test before and after replace mosfet.
Problem goes away
