Lenovo ThinkCentre M71e IH61M MS-7687 Rev 1.0 Schematic
The Lenovo IH61M motherboard, manufactured by MICRO-START INT'L CO., LTD. with board number MS-7687 revision 1.0, is built around the INTEL Sandy Bridge Processor on an LGA 1155 socket paired with the INTEL Cougar Point Chipset. The system utilizes a 32Mb SPI Flash for BIOS storage. Audio is handled by a Realtek ALC662 HD Audio Codec, while networking is provided by a Gigabit LAN controller, the RTL8111E-VB-GR-RH. The Super I/O and EC/KBC functions are integrated into the SIO-NCT6776F. Memory configuration supports 2 Channel DDRIII 1066/1333 UNBUFFERED across two DIMM slots, with a maximum capacity of 8GB. The VRM is managed by the NCP6151S52 controller.
Q: What is the board number and revision for this Lenovo IH61M motherboard?
A: The board number is MS-7687, revision 1.0.
A: The EC/KBC and Super I/O functions are provided by the SIO-NCT6776F.
A: The motherboard uses a 32Mb SPI Flash for the BIOS.
Q: What audio codec and LAN controller are used?
A: The audio codec is a Realtek ALC662, and the Gigabit LAN controller is an RTL8111E-VB-GR-RH.
| Brand | Lenovo |
| Motherboard Manufacturer | MICRO-START INT'L CO., LTD. |
| Model | IH61M |
| Board Number | MS-7687 |
| Date | Wednesday, February 23, 2011 |
| CPU Platform | INTEL Sandy Bridge Processor |
| CPU Socket | LGA 1155 |
| PCH / Southbridge | INTEL Cougar Point Chipset |
| EC / KBC | SIO-NCT6776F |
| Audio Codec | Realtek ALC662 |
| BIOS / SPI Flash | SPI Flash 32Mb |
| LAN IC | RTL8111E-VB-GR-RH |
| RAM Type | DDRIII 1066,1333 UNBUFFERED |
| RAM Architecture | 2 Channel DDR III * 2(Max 8GB) |
| VR Controller | NCP6151S52 |
