Schematic otherbrand compal la-a821p zemaa rev0.1 schematic
otherbrand compal la-a821p_zemaa_rev0.1 schematic
otherbrand=1=compal la-a821p_zemaa_rev0.1.pdf
BrandCompal Electronics, Inc.
Project CodeBay Trail M LA-A821P
Board NumberLA-A821P
Revision0.1
Date2013/05/22
CPU PlatformIntel BayTrail-M Platform
CPU ModelVALLEYVIEW-M SOC
CPU SocketFCBGA 1170 Pin
EC / KBCKB9012QF A4
Audio CodecALC259
BIOS / SPI FlashSPI ROM 1.8V (8MB)
RAM TypeDDR3L
RAM ArchitectureDual Channel
RAM Quantity / Slots204pin DDR3L-SO-DIMM X1, 204pin DDR3L-SO-DIMM X1
Card Reader ICGL834L
LAN ICRTL8106E-CG, RTL8111G-CG
WiFi / WLAN ICNGFF E TYPE WLAN
HDMI Level ShifterRTD2132R-CG
This Compal LA-A821P Rev 0.1 motherboard is built on the Intel BayTrail-M Platform, featuring a VALLEYVIEW-M SOC in an FCBGA 1170-pin package. The system memory architecture consists of dual-channel DDR3L, supported by two 204-pin SO-DIMM slots operating at 1066/1333 MHz. The embedded controller is a KB9012QF A4, and the audio codec is an ALC259. The BIOS is stored on an 8MB SPI ROM operating at 1.8V. Networking is handled by dual LAN controllers: a RTL8106E-CG for 10/100 Mbps and a RTL8111G-CG for Gigabit Ethernet, alongside an NGFF E-type WLAN module. The HDMI interface uses an RTD2132R-CG level shifter, and the card reader is controlled by a GL834L IC.
A: The embedded controller is a KB9012QF A4.
A: The BIOS is an 8MB SPI ROM operating at 1.8V.
A: The motherboard supports dual-channel DDR3L memory via two 204-pin SO-DIMM slots.
Q: What LAN controllers are present?
A: Two LAN controllers are used: a RTL8106E-CG for 10/100 Mbps and a RTL8111G-CG for Gigabit Ethernet.
  • otherbrand=1=COMPAL LA-A821P_ZEMAA_Rev0.1.zip
