otherbrand topstar x01_revb schematic
otherbrand=1=topstar x01_revb.pdf
This TOPSTAR X01 motherboard schematic, dated September 29, 2009, is built around the Pineview CPU platform paired with the Tigerpoint PCH/southbridge. The board is designed for DDR2 memory via a DDRII SODIMM slot. The embedded controller is a KB3310B, and the audio subsystem is handled by an ALC662 codec. Networking is provided by either an RTL8101E or RTL8102E LAN IC. The system utilizes an 8Mbit BIOS flash. Power management includes a TPS6017A charging IC. The board also features a card reader supporting SD/MMC/MS/XD formats and a WiFi/WLAN IC identified as ICS9LPRS365.
A: The motherboard uses a KB3310B EC/KBC controller.
A: The audio codec is an ALC662.
A: The BIOS flash is an 8Mbit device.
A: The LAN IC is either an RTL8101E or RTL8102E.
| Brand | TOPSTAR |
| Motherboard Manufacturer | TOPSTAR TECHNOLOGY / ShenZhen Topstar Industry Co.,LTD |
| Project Code | X01 |
| Board Number | A3139 / A3239 |
| Revision | Ver B / Ver: B7 / R1.0 |
| Date | Tuesday, September 29, 2009 |
| CPU Platform | Pineview |
| PCH / Southbridge | Tigerpoint |
| EC / KBC | KB3310B |
| Audio Codec | ALC662 |
| BIOS / SPI Flash | 8Mbit BIOS |
| LAN IC | RTL8101E / RTL8102E |
| RAM Type | DDR2 |
| RAM Architecture | DDRII SODIMM |
| Charging IC | TPS6017A |
| Card Reader IC | SD/MMC/MS/XD CARD |
| WiFi / WLAN IC | ICS9LPRS365 |
