Technical Support PUERTOS USB NO FUNCIONAN HP 23-Q154LA
djorkaeff
PUERTOS USB NO FUNCIONAN HP 23-Q154LA ALGUNA SOLUCION SALUDOS
hi
First you need to be confident in terms of software and operating system. Next you need to check the usb port voltage to make sure there is voltage 5 on the usb port. And if you do not see a problem, do the next step.
ohm check the data pins in the USB port and announce.
