Schematic toshiba nb520 compal la-6858p qbu00 cougar 2.0 schematic
toshiba nb520=1=compal la-6858p qbu00 cougar 2.0.pdf
BrandCompal
ModelCougar 2.0
Project CodeQBU00
Board NumberLA-6858P
RevisionREV:1.0
Date2011-11-07
CPU PlatformIntel Cedar Trail
Platform AliasTiger Point
CPU ModelIntel Cedarview 2 Core 1.86GHz (6.5W)
PCH / SouthbridgeTiger Pointer
EC / KBCENE KB930 E0
Audio CodecALC269
BIOS / SPI FlashSPI ROM 2MB
BIOS Flash Capacity2MB
EC Flash / ROMSPI ROM 128KB
RAM TypeDDRIII
RAM Architecture204pin DDRIII-SO-DIMM
RAM Quantity / Slots1
LAN ICRTL8105E 10/100 LAN
Card Reader ICRTL5137
WiFi / WLAN ICPCIeMini Card WLAN +BT COMBO
This Compal LA-6858P REV:1.0 schematic, dated 2011-11-07, documents the Cougar 2.0 platform based on the Intel Cedar Trail processor and Tiger Point chipset. The motherboard is powered by an Intel Cedarview 2 Core 1.86GHz CPU and utilizes a Tiger Pointer PCH. System memory consists of one 204-pin DDRIII-SO-DIMM slot supporting 1.5V DDRIII 1066MHz modules. The embedded controller is an ENE KB930 E0, with a dedicated 128KB SPI ROM for EC firmware. The main BIOS is stored on a 2MB SPI ROM. Audio is handled by an ALC269 HDA codec, and networking is provided by an RTL8105E 10/100 LAN IC. Storage connectivity includes a SATA HDD port, and expansion is supported via PCIe Mini Card slots for WLAN+BT combo and WWAN modules. A card reader is integrated using the RTL5137 controller.
A: The board number is LA-6858P, revision REV:1.0.
A: The embedded controller is an ENE KB930 E0.
A: The main BIOS is stored on a 2MB SPI ROM, and the EC has a dedicated 128KB SPI ROM.
A: The motherboard supports one 204-pin DDRIII-SO-DIMM slot running at 1.5V and 1066MHz.
Q: What LAN and audio controllers are used?
A: The LAN controller is an RTL8105E 10/100, and the audio codec is an ALC269.
  • Toshiba NB520=1=Compal LA-6858P QBU00 Cougar 2.0.zip
