toshiba satellite c655d manaus 10ab-10abg_6050a2408901-mb-a02 schematic
toshiba satellite c655d=1=manaus 10ab-10abg_6050a2408901-mb-a02.pdf
[TD]Revision[/TD][TD]X01[/TD][/TR]
The Inventec Berlin 10AD (CSA3485, Revision X01) motherboard is built on the AMD Brazos platform, featuring an AMD APU Ontario 605 (23x23mm BGA FT1) and an AMD FCH Hudson M1 (19mm x 19mm BGA). The system uses a Winbond SPI EEROM for BIOS storage and an ITE IT8518E EC/KBC. Audio is handled by a Conexant CX20671 codec, while charging is managed by a TI BQ24725 controller. Networking includes an Atheros AR8151 or Giga AR8152 LAN IC and an Atheros wireless module. Memory configuration supports two DDR3 SODIMM slots. Additional I/O includes a Genesys Logic GL825 card reader and a GL850G USB hub IC. The board was documented on 28-Jul-2010 under document number 1310A2333201.
A: The motherboard uses an ITE IT8518E EC/KBC.
Q: What BIOS flash IC is used on this motherboard?
A: The BIOS is stored on a Winbond SPI EEROM.
A: The charging IC is a TI BQ24725.
A: The motherboard supports two DDR3 SODIMM slots.
| Brand | Inventec |
| Motherboard Manufacturer | Inventec |
| Project Code | Berlin 10AD |
| Board Number | CSA3485 |
| Date | 28-Jul-2010 |
| CPU Platform | AMD Brazos Platform |
| CPU Model | AMD APU Ontario 605 23x23mm BGA FT1 |
| PCH / Southbridge | AMD FCH Hudson M1 19mm x 19mm BGA |
| EC / KBC | ITE IT8518E |
| Audio Codec | Conexant CX20671 |
| BIOS / SPI Flash | Winbond SPI EEROM |
| Charging IC | TI BQ24725 |
| Charger Architecture | TI BQ24725 |
| LAN IC | Atheros AR8151 / Giga AR8152 |
| WiFi / WLAN IC | Atheros |
| RAM Type | DDR3 SODIMM |
| RAM Architecture | DDR3_SODIMM0, DDR3_SODIMM1 |
| Card Reader IC | Genesys Logic GL825 |
| USB Hub IC | Genesys Logic GL850G |
| Document Number | 1310A2333201 |
10AD
CSA3485
Brazos
CPU Model
FCH HUDSON M1 19MM X 19MM BGA
IT8518E
CX20671
BQ24725
AR8151
GIGA AR8152
DDR3
LOGIC GL825
LOGIC GL850G
10AD
CSA3485
Brazos
CPU Model
IT8518E
CX20671
BQ24725
AR8151
GIGA AR8152
DDR3
LOGIC GL825
LOGIC GL850G
