packard bell tj66 tj65 wistron sjv50-mv
The Wistron SJV50SA motherboard, documented under project code 91.4BU01.001 and PCB P/N 48.4BU01.0SB revision 08244-SB, is built around the Mobile CPU Cantiga platform paired with an ICH9M southbridge. The system utilizes a Winbond WPCE773 EC/KBC and a 2MB SPI BIOS flash. Memory architecture is DDR2 operating at 667/800 MHz. Integrated graphics are provided by the Cantiga GMCH. The audio subsystem is handled by a CX20561 codec, while networking is managed by a BCM5764L LAN/WLAN controller. Power management is distributed across multiple regulators including ISL6239, ISL6266A, ISL6263A, RT9026, TPS51124, RT9018, RTS5159, RT8202, and G7922, with charging controlled by an ISL88731A. The clocking solution is an ICS9LPRS365B generator, and the card reader interface uses a G1454R41U controller.
A: The motherboard uses a Winbond WPCE773 EC/KBC.
A: The BIOS flash is 2MB.
A: The motherboard uses DDR2 memory operating at 667/800 MHz.
A: The charging IC is an ISL88731A.
| Project Code | 91.4BU01.001 |
| Board Number | 48.4BU01.0SB |
| Revision | 08244-SB |
| Date | Monday, February 23, 2009 |
| Document Number | SJV50SA |
| CPU Platform | Mobile CPU Cantiga |
| PCH / Southbridge | ICH9M |
| EC / KBC | WPCE773 |
| EC/KBC Package | Winbond |
| Audio Codec | CX20561 |
| BIOS / SPI Flash | 2MB |
| LAN IC | BCM5764L |
| Charging IC | ISL88731A |
| Power IC(s) | ISL6239, ISL6266A, ISL6263A, RT9026, TPS51124, RT9018, RTS5159, RT8202, G7922 |
| RAM Type | DDR2 |
| RAM Architecture | 667/800 MHz |
| Graphics Architecture | Integrated Graphics |
| Card Reader IC | G1454R41U |
| WiFi / WLAN IC | BCM5764L |
| Clock Generator | ICS9LPRS365B |
91.4BU01.001
48.4BU01.0SB
Cantiga
ICH9M
WPCE773
CX20561
BCM5764L
ISL88731A
G7922
ISL6239
ISL6263A
ISL6266A
RT8202
RT9018
RT9026
RTS5159
TPS51124
DDR2
Integrated Graphics )
G1454R41U
BCM5764L
ICS9LPRS365B
Clock Generator
91.4BU01.001
48.4BU01.0SB
Cantiga
ICH9M
WPCE773
CX20561
BCM5764L
ISL88731A
G7922
ISL6239
ISL6263A
ISL6266A
RT8202
RT9018
RT9026
RTS5159
TPS51124
DDR2
G1454R41U
BCM5764L
ICS9LPRS365B
Clock Generator
